Are pop rivet nozzles made to a common standard?
richard6299
25 Sep 2011
Wakefield
Hi. I have a vintage King Klik pop riveter model T40. Very well made. But I'm missing a nozzle because it was lent to uncle Normam and it did not come back with all the nozzles. I want to go ahead and replace all the nozzles I do have. So, can I buy any make of spare pop rivet nozzle? Thanks. Rich
Oh, I've just discovered that my King Klik riveter is not working, it won't grip even after making alterations to the adjuster piece. So, I'll just buy a new pop riveter, it's not important anymore to know if nozzles are standardized. EDIT: Actually, it could be that the rivet I am using (metric) is not quite the size required for the mechanism to work.. I must try it with the original (probably imperial) rivets.
If you look inside the housing you should see a spring a small tube ending in vee and then two jaws if the jaws are worn they will not grab the mandrel.
New jaws are required. They may work with a larger rivet 5/32 or 3/16 as the mandrels are larger.
Tony
Hi. I went and bought a new pop rivet gun. Whose nozzles do not fit the King Klik pair I have. I'll probably chuck out the King Klik, although I did see a pair on Ebay going for £40. Which is ridiculous probably. Of the many products available, I went for PRESCH (10105). German engineered. Rich
