Mike160304":1jiqqqaf said:AES - Hey, PermaGrit is really interesting. I had not come across them when googling for such things before.
Thanks.
AES":24kyl05k said:I've got a couple of cheapo sanding drums where the sanding sleeve does indeed move up or down along the sleeve. But most of mine don't, especially those where the mandrel has a screw hole and a washer on the top - you just loosen the screw to get the old sleeve off and tighten the screw again when the new sleeve is on.
For the above "slippy" drums I just wind a little bit of tape around before fitting the drum, for the rest, I just tighten the screw until the sleeve doesn't slip any more.
But be aware that there are, of course, limits - if you've tightened the screw to a reasonable level and the sleeve still slips it's probably because you're pressing too hard. That will probably burn the job anyway, so it's no bad thing when it starts to slip - it's telling you to ease off the pressure.
Mike160304":1s6qsdgc said:As noted above, can't find any on PermaGrit site?
I use AliExpress/Ebay UK depending on what I can find and how long I am willing to wait.
