Anyone near me that can sharpen my tools?
alanjparsons
2 Aug 2013
Weymouth
Hiya,
Managed to dink one of the ends of my tools last night #-o
Anyone from Dorset that could sharpen it for me? happy to pay you for your time and skill!
I am in Weymouth but can travel
Rather worried that you are asking such, do you not sharpen your turning tools on daily basis if not an hourly or even minute by minute dependant upon task?
Unsharp tools are a hazard and in my opinion an accident waiting to happen.
Or is it just that you are nervous about removing the extra metal to reform the damaged edge, if that's the case just take things slowly and give yourself time to correct any deviation from the preferred form as you go.
Have you got a grind stone and any form of sharpening jig to use yourself,or even free hand.What tools are they that need attention??
There is plenty of good info on the forum re sharpening and making your own jigs.
You've gotta get used to it one day or another and sooner the better.
Practice practice practice is the only way.
There's a sharpening workshop at Holton Heath, just outside of Wareham. I'll try to remember to take the number next time I drive past.
Axminster tools have a tool sharpening service I believe.
They are in my good books today. the chuck jaws arrived (post free) :)
Had I known earlier I would have had them go over my new tools so I could start straight away.
alanjparsons. I'm a long way from you (near Reading) but if you're up my way I'd happily demonstrate my approach to keeping turning tools sharp. You will need to get your own setup but perhaps a little friendly direction would help your aim :)
I am only guessing, but may have same problem
I have the tools ...unused
I know I gotta sharpen them before I use them ...but a live demo would be a confidence boost
Steve
Why send off tools as often they can take up to a week before you get them back many sharpening companies would have no idea of all the different grinds. When I am turning and not making wooden cars and rockers I just want to be able to turn when I want
Like most have said get someone to show you if you can you can even make your own jigs to help here is one to start someone off.
http://www.turningtools.co.uk/widgets/grindingjig/wtsharpen.pdf
SteveF":2dqx7s24 said:
do all axminster have sharpening service ?
Is it expensive?
Yes, I think they all offer this service, but I'm sure it's primarily aimed at re-grinding planer knives and TCT tooling. I think they'd look rather bemused if you turned up with a set of turning tools.
As most other people have said; If you take up woodturning you'll NEED to sharpen your own tools..... often. A bench grinder is almost as necessary as the lathe itself. It really doesn't take much effort to knock up some simple jigs to make sharpening quick, easy and repeatable.
I can understand the desire to have someone show you how to do it, correction how they do it, I am sure my learning curve would have been a lot smoother if someone had actually shown me, in the flesh how to not only go about it, but the different profiles too. Too steep or shallow a bevel will do this or that and so on.
Also if one is new to turning and starts with 2nd hand gouges, one may well assume that the tool is ground correctly and become very frustrated when one cannot get the tool to work as it should when you're sure you are doing as instructed. To help along these lines one can buy profiles to copy, for example .. http://www.henrytaylortools.co.uk/profi ... tools.html
A visit to a club in this instance is very worthwhile , even if you're an unsociable old so and so like me.
sounds a plan
my tools are new so assume they are ground correctly
but also assume they are blunt
i have the tools \ grinder just don't want to bollo£$%% up a new set to find out i dont have a clue :D
SteveF":1pubciz8 said:
sounds a plan
You won't have a clue until you have bollo£$%% up a new set a few times! It's all part of the learning curve.
+1 to Jacob's comments. Don't worry too much...they are metal after all! Most of us spend half our lives complaining about how slow the grind is to remove metal...so you're unlikely to do any real damage. Read around it, youtube...whatever to get the general idea then just have a go. Its the old adage.....no-one learned to ski without falling over a few (hundred) times
I cheated a little and bought second hand gouges, fully aware that the first thing I was gonna do was re-grind them to different profiles to see which worked for me.
I am still using those gouges and haven't yet seen the need to buy brand new tools. I will have to soon but for now I am good.
As others have said, watch some of the videos on YouTube (start with mike waldt) and work from there.
Coll
As someone very new to woodturning as well I can sympathize :)
Visiting a few wooturning clubs helped me a lot. I have been to three actually, and members were so helpful and willing to give advice.
I also bought a second hand bowl gouge, and butchered it quite a bit to give it an Ellsworth grind. Same with my second hand skew. I gave it a domed bevel following the advice from a video, didn't liked the result and also spoiled the radius of the edge, so I ground it back to the normal concave bevel and fixed the radius too.
They are both really good steel and they came from a retiring woodturner who made them razor sharp before selling them. I felt a bit bad for having butchered them, the gouge was short to start with and now there is little left of the flute for the jig to clamp on. But hey, it's just steel, and I learned a lot.
If I were you, I'd shamelessly call a club up and ask if you could show up early at a meeting with your tools, and have someone give you a quick demonstration on how to sharpen.
Typically they'll have a demonstration on the day, so they might set up the grinder anyway.
I am really not the best person to give advice, as I know so little, but, based on my mistakes:
1) I see many experienced turners don't really measure the angle, just grind to what they need. But if, like me, you want a protractor to give you a starting point and knowing what you are starting with, get one in metal :D Plastic doesn't like warm tools just out of the grinder..
2) Take a photo or two of your tools before you grind, it makes so much easier to rectify mistakes
3) At first, stick with the normal grind for the gouges, if that's what they come with. In the end, I am appreciating the Ellsworth grind, but it's still far from perfect and got me really frustrated at first.
4) Many don't find it all that useful, but I like honing the tools often. The skew at least. The small diamond stones with handle work better than other types for me, and taking the tool rest off and using the banjo to support the butt of the tool helps a lot keeping it straight while honing.
5) If you want a jig but don't feel like making it yourself, there is a guy on ebay, a turner from cornwall, who makes them. A large platform and the jigs for normal grind and Ellsworth grind are around 50 or 60 pounds I think. They are not perfect, mine requires some shims to stay truly perpendicular to the wheel, but they work ok.
Obviously, some of the above suggestions might not be all that great after all, hopefully somebody experienced will correct me if that's the case, but that's what works for me right now.
Happy turning!
Aldo
Dorset Sharpening Services
Suite E3, Romany Centre Business Park Wareham Rd Holton Heath, Poole, Dorset BH16 6JL‎
07515 595609
More like a shed than Suite, but the sign says he can 'sharpen almost anything', just in case someone takes in a tub of ice cream I guess.
