Hi everybody,
a while ago you gave me much valuable advice on re-toothing an old dovetail saw, back in this thread:
http://www.ukworkshop.co.uk/forums/life-after-death-for-my-back-saw-t54710.html.
I'm now considering reworking another saw, this time a 22" handsaw which I bought some time in the 90s, I think, but which has languished in the discard pile for some years. It's made by Sandvik, and you can see it in all its plastic-handled glory here:
My intention is to remake it as a small ripsaw (same tpi, maybe 5° rake); I would have considered this fairly straightforward were it not for the current profile of the teeth. Instead of the normal 60° internal angle in the gullet, it seems to be more like 45°, and the side-on profile is more or less symmetrical forwards and back - see this close-up:
So, my question is how to set about this. There seem to be two possibilities:
a) I could grind off all the existing teeth and start from scratch. Given that my previous attempt at starting from scratch (earlier thread, linked above) was such a nightmare, I'm a bit reluctant to go this route ... but I'll do it if it's the right way.
b) Instead, would it be possible to progressively re-shape the existing tooth profile to that required? It seems to be a rather radical change of shape. Would this be easier than (a), though?
Which approach would you take? If (b), any particular tips? Or some other approach entirely?
(PS: I discount the possibility of re-sharpening the saw retaining the current tooth profile - I think I would need different files and techniques to do this, neither of which I'm prepared to acquire).
Thanks for any advice you can offer
Chris
Chris
