Andrew Crawford Jewellery Box WIP
frugal
29 Dec 2007
Dursley, Gloucestershire
I have been gradually working my way through Andrew Crawford's The book of boxes. I am currently trying to make the last of the boxes which is a veneered jewelery box. I want to try to make this as detailed as I can and point out why I have done the things that I have done, but I do not want to make it a pattern to follow. After all Andrew has spent a lot of time and effort writing a really great book, so if you want to know exactly how to make this box, have a look at the book.
The first thing was to make up the sides of the box base from MDF with a small piece of hardwood (sycamore in this case) for the sharp bottom edge.
Then while the glue was drying I made up the templates that will be used as the shape of the sides and the top of the box. Each template has a positive and negative version so that I can create the sides and the formers that will be used during veneering as I do not have a vacuum press.
The next thing to do was to make up the former for the lid. This will be used inside the lid frame to support the top when it is glued into shape. This was done with a No. 4 plane and a hollow plane I bought a couple of years ago and have only just found a use for ;)
I then realised that the veneer I was planning to use needed to be flattened, so I made up a mixture based on Richard Jones recipe and liberally applied it to the veneer. I should say at this time that I am making two boxes at the same time, so I have two different sets of veneer, some burr Myrtle and some burr walnut. The walnut is flat, but the myrtle needs some flattening. When I applied the mixture it really brought out the figure in the wood. (The veneer was really wet when I took the photo).
The veneer was then put into my hi-tech veneer press between pieces of plastic mesh sacks that were originally used to hold metal tubing when it was shipped and layers of newspaper to soak up the moisture. The whole lot is gently pressed together. I was really skeptical of the process when I first tried it, but it does seem to just work and it really makes the veneer flexible.
I will need to take the stack to pieces every day for a few days to change the newspaper until the veneer dries.
I am hoping that I will be able to use the same simple press to form and veneer the lid.
In the mean time I spent some time with a hollow plane shaping the sides of the box to roughly the right shape
I have never really logged how much time I spend on a project, so I am going to put at the bottom of each post how much time I have spent on each activity as a record.
Time taken so far:
- Templates, patterns and formers: 2 hours
- cutting gluing and shaping the pieces: 2 hours
- Sorting and preparing the veneer: 1 hour
Total so far 5 hours.
I got out for a little bit this afternoon. I managed to cut out the hardwood for the frame of the lid and get it mitred. Once I had the lid mitred to size I was able to mitre the sides of the base to the same size.
Then I got the frame of the lid glued up. Unfortunately I only thought about taking photos after I had it all taped up. I will try to take a photo next time I am out.
I also had a look at the veneer that had been pressing overnight. It had gone from hard and bumpy to wonderfully flat and flexible. I changed the newspaper and put it back in again to dry some more. Hopefully after another couple of changes of newspaper the veneer will be dry enough to take out.
Total time taken to date:
- Templates, patterns and formers: 2.0 hours
- cutting, gluing and shaping the carcass: 3.0 hours
- Sorting and preparing the veneer: 1.25 hours
You're a very brave man to be logging your hours publicly like this!! :shock:
:D :wink:
I think a very wise man.
Even at a non-commercial £20 p/h, frugal has £120+ worth of domestic credit banked already.
I see a new tablesaw (with a big scoop of cast iron included) as fair exchange for this little baby when it is ready!!!!
Onward brave man................
Simon
In That case can you come round and explain those economics to SWMBO ;)
The next thing to do was put a lid on the frame. The thinnest ply I had was was 3mm and there was now way that it was going to bend into the shape of the lid. So I had to wait a while whilse I ordered some 1.5mm ply.
The lid is made of two sheets of 1.5mm ply each pressed onto the frame with a former inside the frame to hold it up in the centre and a second former to press it down from above. After the first sheet was dry I added a second sheet on top.
I have also started to put the first pieces of veneer. I have veneered the edges of the lid and the carcass and applied some veneer to the top of the lid. Next I need to veneer the sides and then start the difficult bit which is going to be inlay and edging.
I've got his books , but veneering as not yet attracted me to this type of work todate, however your craftsmanship is obviously working well.
I went out this morning and had a look at how the veneering had gone overnight. The lid has come out pretty well, but there are a couple of issues.
Firstly I did not glue the 4 quarters together first, I thought that I could get away with just taping them all in place and letting the glue do the job. I think that this has lead to a couple of places where the joint is not very neat. There is also a little bit along one of the seams where the glue has not taken and I think I am going to ned to lift it with a scapel in order to get a bit more glue under there.
Secondly the burrs in the veneer mean that the top is a little bumpy and I am going to need to sand it quite a bit to get it flat.
Total time spent so far:
- Templates, patterns and formers: 3.0 hours
- cutting, gluing and shaping the carcass: 4.75 hours
- Veneering: 1.5 hours
Frugal - very brave to undertake that box.
I have the same Andrew Crawford book and, over the years, it has inspired me to making a variety of his boxes.
But, as said above, I too have not got into veneering yet.
That is really fine work so far - looking forward to seeing the completed article. 8)
Dave
SWMBO gave me one of Andrew's courses for a birthday present. The course is in the middle of May, so I thought that as the veneered box is the one I have the most questions about, that I should have a go at its o that I know exactly which questions I want to ask when I get there ;)
Sportique":2wwjqkb5 said:
(PS must introduce my SWMBO to yours :wink:)
My wife kindly gave me the Boxes book and a voucher for a course with Andrew for Christmas 2 years ago as a way of rekindling my interest in woodworking. Two days later I found this place and it has been downhill ever since ;)
This year for my Birthday as I had kept failing to actually go on a course, she just booked one for me :oops:
Eeep! It has been nearly a month since I last did an update for this. This is mainly because I a bit of a disaster with the veneering and came close to doing a Rob and shoving the whole lot through the bandsaw ;). I have now overcome these and have been working feverishly on it as I am leaving for the course with Andrew tomorrow afternoon and I want the box in a state where I can ask questions about the next steps and not have it look like I have just started it.
I had two problems. The minor problem was that I had not used even pressure on the lipping on the edges and the lid rocked quite a bit on the base. On further investigation, my attempts at sanding it down had domed the lipping slightly so that there was a small reveal when the box was shut. Just enough to be really annoying.
The major problem was that I had a complete brain failure when veneering the top. The top was quartered veneer and the front and back were book matched veneer, so obviously it was important to get the line where the veneers joined to match up. Unfortunately it was a bit late at night when I veneered the top and I had forgotten that I had not trimmed all of the quartered pieces to the same length. I then for some unknown reason decided to make sure that the overhang was the same on both ends, which meant that the centre line of the top was not in the same place as the centre line of the front. Not noticing this I then veneered the back carefully matching up the centre line of the back with the centre line of the top (and thus making that off centre as well). Given that this veneer needed quite a bit of flattening and I now needed to either throw it all away, or restart the veneering from scratch I decided to have a stop and a think for a while.
About a week or so later I came back to it and decided to use the walnut burr veneer that I have cut to rough size for the second box instead. So I carefully took a block plane to the lipping around the top of the box and removed it. Then I carefully took the block plane and flattened out all of the sides so that the lid sat on the base without rocking and with out any kind of a reveal. I then re-veneered the lippings.
Once this was done I then carefully measured the middle of the front and the back and applied the veneers to those faces (over the previous attempt at veneering). Then I did the ends (which were a single piece and not book matched). Only then did I do the top, carefully lining up the centre line with both the front and the back veneer centre lines.
As you can see from the photos the veneer does not meet up neatly at the edges of the box, and it does not extend all the way into the corners of the front bottom corner. This was intentional (well, not intentional, but I have a cunning plan). The veneer is not going to be running all of the way to the edge, it is going to have a banding and then a lipping of hardwood at the very edge.
So the next thing to do was to make up the banding, unfortunately I did not get any photos of this. The basic technique was to make a sandwich of dark, dark, light, dark for the outside (this sandwich was made twice the width of the others and cut lengthways to get two identical ones once it was dry). Then a sandwich of dark, dark, light, light, dark, dark, and a third sandwich of light, light, dark, dark, light, light. One of the sandwiches was cut into 5mm length across the grain. The other was cut into 3mm and 25mm lengths across the grain. Then the small pieces were assembled into the correct order and glued onto one of the outside pieces. Once that was dry the other outside piece was glued onto the other side. Once all of this was dry I cleaned it up on the shooting board and hopefully this is what it should look like when it is applied to the edge of the box:
The photo shows me holding the banding and a piece of sycamore against the box to show how it should look.
As usual all of the photos are links to the picture on Flickr if you want to see the higher resolution images. For these photos I have just wiped a little white spirit onto the wood to bring out the grain for the photos, unfortunately it has also shown a couple of areas that have residue glue and where the masking tape has left a slight residue. Any ideas on the best way of removing masking tape glue that has been set on with pressure of clamping?
- Removing Veneer and cleaning up: 2 hours
- Veneering: 3 hours
- Making up banding: 2.5 hours
Total so far: 18 hours.
I think your box is coming along very nicely, and if it is a new skill you are learning I think you are being too critical of your work.
Most things in life are skill learning and your box is way above the basic starting veneer process.
Overly self critical appears on my work performance review every year ;)
