Cottonwood
I have begun to butcher my workbench :shock: well actually it WAS in a pretty rough state. It needs tidying up, reduce the length by 2 feet to 8 feet. I inherited it when I moved to Bournemouth (now living in Suffolk), it was built around 40 or 50 years ago using 10 x 2 pitch pine for the 2 top boards and smaller 5 x 1's for the well boards. The legs are a bit ropey, the council joiner who owned it previously seems to have used various bits of corporation door and window frames (some of them pink lead primed!) to patch them together. It has a good record 53 vice, which does need an overhaul. Anyway I will post some pictures of the job when its finished, I plan to replace the legs with 3 inch square solid redwood posts and 6 x 2 braces. I was going to take off the top surface with scrub/jack etc & etc, then thought :idea: why not simply turn the boards over as the pitch pine is still in good condition. So I have been removing the nice little plugs that cover the screws. Those slotted steel screws are very nice, in fact I might well reuse them....
Anyway, what I didnt notice until today was a good planing stop right there in my bench. At one time there was a vice on the other side of the bench, but I never paid any attention to it, or the planing stop, which had been almost completely hidden, pressed down and filled with crud/dust/plaster/cement etc. When I tapped it out this is what appeared:-
It looks to be shop made from carefully shaped and filed angle iron, screwed into a 2 inch square oak post that is height adjustable with a large bolt and wingnut, and it looks like the teeth are angled so that when the board to be planed is pushed up to it, it gets pressed down to the bench.
Anyway thanks for looking, Jonathan![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![](https://proxy.imagearchive.com/35c/35c65b25a56089bfa83625b2601e2c5c.jpg)
![](https://proxy.imagearchive.com/761/761565c06367565d93bcc79233f97fc2.jpg)
![](https://proxy.imagearchive.com/f7c/f7c312214c577816c3e2f66cd99b47cc.jpg)
