xy mosian
Hi all,
For some time I have been considering some sort of depth guide for use with augers. I am thinking of augers of the older type used with swing braces. Sticky tape around the auger works well..ish. The area for sticking is very small and the results can be less than truly useful. The problem is worse when drilling at an angle as anything with any bulk tends to foul the work before the required depth is reached.
Today a solution light bulbed its way into my head. A short length of 19mm plastic overflow tubeing, with a lengthways slit. The image will explain it better. The tape is used just to give the tube more grip. As waste creaps up the auger flutes it can dislodge the tube but with care I found it worked well.
I hope you may find this useful,
xy
edit. It will not work on augers less than 19mm of course.
xy
xy
xy
