Advice on which lathe.
25 Feb 2012
Stranraer
Hello again....I was on here about 4 or 5 years ago struggling with everything to do with wood turning. I have an old Sealey lathe with a duplex multistar chuck. It's been a constant battle but I have managed to produce some reasonable 'rustic' work :shock: . Now its time to upgrade so I can start turning larger bowls and platters to burn designs on. A wooden canvas in other words.
So...I have been given a Fox F46-717 lathe. It's missing the on/off switch and V belt which is easy enough to replace. But it has no tool bar thingy or rest and I don't know where to get these from. It has no chuck either.
Last night I went to look at an old Coronet 3 in pristine condition. The guy want £200 for it. It comes with all the attachments, tools...everything. It looks like a solid machine.
Then today a friend offered me his P Pro 305mm Wood Lathe with all the attachments...but I feel its not a good lathe.
Can anyone help me make a decision? Fix up the Fox lathe which might work out expensive? Spend £200 on Coronet Lathe and I'm good to go? Or take P Pro lathe for nothing?
Thanks...Jane
Can't help with choosing a lathe, but just wanted to say you've done some beautiful work - loving the detail did you pyrograph some pieces?
:D
I can't really comment a great deal but have found the record lathes to be reliable and being able to bolt down easily to a bench is nice.
Nice looking work too.
I had your choices I'd go for the Coronet 3 and not mess about fixing up the others.
Hi Stiggy....thanks for your comment. Yes, I use a pyrography machine to burn the designs on :)
Thank you Tetsuaiga. It certainly looks like a good solid machine.
RogerP....I was erring towards the Coronet but wasn't sure...so thanks for the advice.
if you have the space, the p pro might make a useful buffing machine. But I would go for the coronet. You could easily spend a bit on the fox, and have a rubbish lathe with new bits on.
Providing it's in good working order the Coronet is probably the best bet.
