Bradshaw Joinery
HI Guys and indeed gals.
I am looking at moving shop into a bigger steel framed building initially size 8.8mx10m with potential for more space later. The building is steel framed rsj construction with asbestos roof on timber perlins and breeze block walls to the eaves,
The floor is concrete slab ontop of compacted foundry ash base.
My main concerns are to insulate as well as possible for minimal cost. but i want a system that is going to last and not damage the building, ie, condensation behing insulation/water under roof/above insulation.
My initial plans are to spray foam the asbestos roof and gable ends, but would the foam attached to the roof directly cause issues to the timber purlins with condensation/if there was a leak? Would it be better suited to remove the asbestos roof alltogether and use composite sheeting? Obviously more costly.
Possibly use non foil faced recticel insulation on the walls with a thin ply facing upto a certain hight. I can paint the floor and roof white or something so it looks better as i have a spray pump, so having a foam finish isnt an issue...
the floor is my main area of concern..... what are my options here, lay insulation and a floating floor ontop, leave it as it is, or build a timber sub floor with a membrane under it, insulate it, then overboard.
Alot of questions, but i want to fully understand the costs i might encounter should i go ahead.
