This might be better directed at another forum, in which case, point away please
In my front garden I have a 4m high Acer growing in my front garden. The trunk, which splits quickly, is about 10-15cm wide and is growing about 60cm away from the front wall of the house. A light layer of gravel covers the ground. Right behind the Acer on the wall is the only downpipe for the front of the house and it would seem an ideal place to put a water butt. I'm thinking about a 280 litre one with a roughly 1000mm x 400mm base.
Something like this. 280 Litre Water Butt - Sandstone (as a side note why are they so expensive, other that the round black ones?)
Can I put this straight down on the gravel which is probably over the tree roots, or is this likely to cause an issue with compacting the soil underneath to an extent it would harm the tree?
I could place it on a few bricks at space intervals, which would increase the point load, but leave 'breathing' room. It would have the advantage of lifting the outlet further off the ground.
