RogerS
SWMBO has triumphed again in her choice of fitting. Maximum points for style. Null pointes for practicality. She chose a Cloud 9 bath filler from Hudson Reed (bought luckily before the price went through the stratosphere.). They have a designer spout to mix the hot and cold. Not like REAL taps that have a spout each. Just connected them up.
The flow is so dire that by the time the bath is full, the water in it will be cold and/or one will be drawing one's pension. It truly is bad. I've replaced the nozzle with the only other one that came with the taps. The flow is a little better. Not much. You might get a tepid bath if you are lucky.
How can they produce something this bad? What is the phrase ...form follows function?
If I was re-plumbing the house from scratch I would fit a pump in the feed from the cold tank and one in the feed from the hot water cylinder. But I'm not.
Time for t'pub.
Time for t'pub.
