I have two pieces of very nice tiger oak courtesy of Custard to make a box. First job is get a couple of new bandsaw blades and some suede - I'm not sure whether to go for green, blue or red - from a practical point it'll need to be relatively dark because the box is designed to be used.
I need to know the colour of the suede because other decoration will depend upon it. I aim to turn a strip/block or maybe two the length and half the width of the box with four or five turned, lidded bowls (on one) with inset semi precious cabs or possibly dichroic glass in silver bezels in the shallow knobs. I have silversmithing tools, a smith's bench and a kiln for the glass . I've seen some very nice s/s and brass hinges (Andrew Crawford) but not a good s/s lock. I have plenty of oak, but I might use padauk for the lid (I probably will for the insides) depending on whether or how I inlay it - the oak is a little busy for anything complex.
I will deep the longest piece into three as it won't do four safely and two will leave me a fair bit of planing by hand, and if you look at the picures the medullary rays are more pronounced on one side (nearer the quarter) so I'll use the two matched faces of the slices from that side. The edge of the smaller piece has had a couple of coats of TruOil to get an idea of the final colour. I have some laburnum which is large enough to saw down for the insides, so I might decide to go native and forget the padauk.
I think I'll make the insides first and box last - it'll let the wood stabilise after being sawn, and the insides will be more demanding than the actual box.
All thoughts, ideas and (some) criticisms welcome.
