Kiteman
Hi,
I have a problem - I need to cut a spiral notch in a disc of plywood. I haven't decided on the exact dimensions yet (I don't know the limits of the materials yet), but the notch will be roughly 3mm wide and deep, in a disc roughly 200-250mm across and will spiral down to a smallest diameter of roughly 50mm.
Obviously, the best tool for the job is a router, but I don't own one. I'm not keen on buying one (I'm unlikely to need it again), so I need (somebody's) advice: what other options are there for cutting the notch?
The relevant power tools I already own are a hand-held drill and a rotary tool (a Woolworth's version of a Dremel) - is there a technique that employs these (maybe a special bit that is much cheaper than a new router), or do I have to re-learn what few chiselling skills I picked up in woodwork lessons 25 years ago?
Thank you in advance for your help and advice to a non-woodworker.
K.
K.
