A Question for you
Blister
10 Nov 2006
Boston Lincs
May sound silly but
I always ask if unsure :oops:
Does anyone know why carving mallets are cone shaped ?
Normally wider at the top and narrower at the bottom ?
Now my 2 balls have dropped
On the porch floor in a parcel I may have a go at turning a mallet
If the move does not get in the way :roll:
If you want to hit the chisel harder you use the thinner end...the energy is more dense. And vice versa. Then on the other hand I could be talking complete rollox :shock:
Coming from the point of view of physics rather than practical experience...:
If there's any effect at all, I think it's more likely to be the other way around - the further the point of contact is from the pivot of the swing (your shoulder/elbow/wrist depending on how you swing) the faster it's going to be moving, so the more energy there is to transfer into the chisel. But then, the mallet's going to stop entirely when it hits, so probably all that energy gets transferred regardless of where on the mallet hits, unless you hit the chisel so low down on the mallet that the rest of the mallet pivots around it and moves past it!
Density comes into play because the heavier the thing that hits (denser if the same size, or larger, if a similar density material), the more momentum it has when moving at the same speed, so the more energy can be transferred - imagine the difference being hit by a 2m/s steel lump hammer and a 2m/s chunk of packaging polystyrene! But I wouldn't expect that this part has much of an effect with a mallet, since the entire mallet is going to stop once it hits anything anyway, so it should transfer the same momentum regardless of where on the mallet you hit with.
The other similar factor is the pressure of the impact itself - how small or large an area the force is spread over (e.g. the difference between being tapped by a hammer or being tapped by the nail that's being tapped by that hammer), but again, since the contact point with the chisel will be roughly the same, that comes into effect at the other end, and explains why sharper chisels cut better - because there's a smaller surface at the leading edge of the chisel moving into the material. ;-)
Hitting squarer makes more sense to me - since if you hit off-square you're likely to tilt the chisel by accident and not cut where you wanted to - but does that mean that with a conical mallet I should be swinging as if to hit half-way down the length of the chisel instead of at the tip? I can't say I've ever noticed a particular problem with my square-ended mallet!
Is it not so if they start rolling when you put them down they go in a circle rather than straight off the bench onto your toes? I have never really thought this through either but there must be some sort of reason for their shape. Perhaps it is just for looks.....
Studders was bang on , same reason as a joiners mallet is angled, so the impact is square on to the end of the chisel (hammer)
Complete rollox :roll:
Hard or gentle you aim to hit the chisel with the point nearest the centre of gravity - roughly the middle of the head, which might account for the taper i.e. puts the C of G in the best place for a natural swing to hit the chisel square on.
If you miss the C of G then some of the impact is transferred back to your hand.
I know...it was said in jest.
Blister":3rshe5yt said:
... at the top and narrower at the bottom ?
Bit of a double take their B, I had to read that bit twice...nicely paragraphed :lol: - Rob
I was taught by old George (who was head wainwright to King Alfred) many years ago to make your mallet so that the angles of the two sides of the head would intersect at your elbow , thus ensuring a square strike :mrgreen:
That's what Aldren A. Watson says too!
"Both faces canted back to assist in striking the chisel squarely".
The swing is an arc.
Rod
