I need to bend 4mm plywood, to a tight radius of 400mm and 1500mm height.
Do you think this is going to be possible, I am building a replica of the dimensions as we speak to see if it is infact possible.
I'm soaking the plywood also to see if that gives me a better result but a bit worried as I need to glue 4-5 of them together when they are done :roll: .
How much would it cost me to get them vacuum done and how long would that take should my solution not be possible? I need about 30 of them done and they are all different. So I suppose it will be a fortune .
Imagine the outside radius (as that's the only smooth one I can draw ) but on the inside. Radius is 400mm and height 1500mm .
