3 phase
thecoder
24 Apr 2011
Pontefract
Am I right in thinking that if a machine is 3 phase it cant be used in a domestic wiring setting ? or can it be used with a transformer ?
Not a transformer but sometime with inverter but some one else knows a lot more about that than me!
Broken link Tony
If the machine is 3 phase 230-250v then you need a simple inverter. If the machine is 410-430v then you need a larger converter, which one will depend on the machines requirements but both inverters and converters can run off domestic supplies. In some cases the motor can be rewired to only need an inverter or even just a single phase domestic supply. Once the link works you will have all the info you need.
Tony Spear":150pmk0y said:
Funny!
That's exactly what I posted! :?
Note quite Tony, You posted:
Code:
http://homepage.ntlworld.com/bob.minchi ... Issue2.pdf
Dave posted:
Code:
http://homepage.ntlworld.com/bob.minchin/Induction%20motors%20-%20Issue2.pdf
If after reading my paper on the subject, you might find this diagram useful in selecting the way ahead for your three phase machinery.
One of these days I'll add it it in formally but for now if you have any questions, feel free to raise here or PM me
Bob
