Hi,
I have a small home-made lathe driven by an old Black & Decker drill (sensitive woodturners should look away now ). The business end of the drill has a 3/8" 24 tpi UNF threaded hole (the 1/2" capacity chuck has a corresponding threaded male stud; this is unlike most modern drills, I believe, where the chuck is female, and the drill male).
Anyway, I have been pondering for some time how adapt the business end of the drill so as to end up with a 3/4" 16tpi threaded male stub. This would allow me to take advantage of a whole range of goodies designed for the small Record lathes. I've found plenty of ways of of getting from 3/8 to 1/2" (this seems to be the other commonly used thread on drills), but nothing which will take me all the way to 3/4".
So ... I'm looking for a 3/8" to 3/4", male-to-male, UNF adapter; if necessary, though, either end could be female - I'd just need to add threaded rod to the female end.
Has anyone any bright ideas, please? My metalworking skills are pretty limited, so the solution would have to be pretty-much off the shelf.
Chris
Chris
