3.5a power supply
Joe Shmoe
8 Mar 2008
Hi. I've got a 24v 3.5a power supply (the kind you use for video games or kids pianos etc) but the cables aren't long enough for what I want. I know I could use an extension lead and just plug the power supply in that, but wondered if you can get special cables that connect to the power pack and extend the length of the cable?
Anyone know if and where you can get these?
Cheers.
Perfectly safe but not waterproof (I don't know if that is a consideration or not?). after all said and done, we're talking ELV of only 24v.
i normally just hack the cable and put an extra bit in the middle
solder or wago's
u may get a voltage drop ...so take this into consideration
Steve
I think you may find that the most significant drawback to extend on the outlet side.
MMUK":2gydrdhe said:
Voltage drop over 5m at 24vDC is going to be negligible :)
Hopefully, but it's not just the extra cable but the connector which is likely to degrade with use. I'd rather extend the mains supply as that is much greater than required by the psu and any reduction [also negligable] will not affect the final output at all.
All academic really as either way will probably be sufficient.
Cheers guys,
I've just read that I need an AC 24v 3.5a power supply, and not to use DC as it will damage the product.
What's the difference between them? Do general plug in power supply units have the option of switching between them? I seem to recall they do, but haven't had one in years so cannot remember.
Joe Shmoe":xzwxoix7 said:
Cheers guys,
The difference is that DC current flows in only one direction, AC current alternates direction 50 times per second on the UK grid.
If you can let us know what you need this PSU for, we can better advise :)
Cheers guys,
It's for a PTZ cctv cam. I've ordered it but I don't think it comes with the power supply. iTs supposed to be Poe+ but my NVR only delivers poe, so I think I will need a power supply rather than buying a poe plus injector as that will probably turn out more expensive?
Man, I am rubbish with technology lol. I'm dreading setting up the thing lol.
i guessed right :)
let me see if i have one at work on tuesday
no promises as have 4 large boxes of power supplies to go thru
will let u know as soon as checked
Steve
Cor that's expensive as I figured I could use one of the £8 units from Maplin etc. I think I'd rather spend another tenner and get a PoE plus injector, and save the hassle of wiring up etc. I've got several PoE powered domes already, which the NVR powers. Annoying that it doesn't do the new Ptz. Grr.
