230v 50hz 4w
Joe Shmoe
8 Mar 2008
Hi guys,
Ive got a second hand cctv camera that i want to use. Its a high voltage model apparently, and says on the body that it's 230v, 50hz, 4w.
There is a small length of wire coming out of it (Live, Positive, Neutral).
Can I wire a plug on and run it on mains, or do I need some kind of PSU.?
Thanks.
Hi
That is designed to run on UK mains supply - make sure you use water / environment proof connections if it is being used outside.
Regards Mick
Also if it is going to be used outside, ensure the supply is via a RCD breaker, if your supply is not through a RCD, you can obtain one of the plug in types, as used for portable power tools. Available at all DIY or electrical stores.
Also fit a 3amp fuse in your plug top, or if you can obtain one, a 2amp.
Take care.
Chris R.
