Hi guys. I need a plug to hook my 3 phase 3kW bandsaw up to the output of the Transwave 5.5kW/400V rotary phase converter I recently bought.
The socket fitted on the converter is a red PCE (Austria) 5 pin 3phase + neutral + earth 16A/6hr IP44 item, but the bandsaw has a 32A plug fitted (this was what the previous owner had standardised on) which is physically much larger.
Do I have to buy a specific PCE made plug to suit the socket on the converter, or will any IP 44 5 pin 3 phase plug fit? i.e. are the physical dimensions standard/are they interchangeable?
If it does need to be a PCE, does anybody have any suggestions for a source?
Thank you
Thank you
