14 ins face plate.
Abudigin
16 Jul 2018
Darwen
Happy new year to you all. The question is, I have a 14 ins faceplate that I wish to use as an outboard sanding plate, is it possible to buy an abrasive paper of this size and where can it be purchased. The largest size I can find is for the Record disc sander which is 300 mm.
Thanks to all in advance.
I think abrasive sheets with spray contact adhesive onto a suitable backer might be the usual thing? then you can get any or as much coverage as you need...
Thanks for the reply will look into that option.
Thanks for the reply, those mentioned will do the trick nicely.
You can get Velcro backing pad for ease of changeover.
You can use smaller discs if they are easier to come by. Don't have to be the full 14" but it's good if they are.
