I want to try and build a Vacum Chuck for my S/B,Union Lathe.I will need a Spindle Tap to match the threads on my lathe.Toolpost does not seem to have my size,could someone tell me were I can obtain said Spindle Tap.
Paul
Paul
Thanks,Would a Tap made of HSS ,be ok to use,Thers someone selling a set of 3 Taps £120 ,too much for me ,but I have made contact with a company who's selling a second hand Tap for £40 plus £8 delivery too Belfast,I don't know which level of Tap it is,but ,would a Tap in good shape be sufficient to cut into wood,without having to use 2 other Taps to get a good result.chipmunk":2axzitno said:Southbend is a US company and so I think you'll need a UNC (60 degree) form tap.
Tracy Tools sell them...
http://www.tracytools.com/taps-and-dies/UNC-taps?product_id=941
If your lathe is an old UK lathe like a Jubilee or Graduate them you'll probably need a Whitworth form and in this case it'd be best to contact Tracy by phone and see if they have one.
HTH
Jon
Thanks Kindly for your help.When you say Tapping Drill ,do you mean a bit to drill out your hole ,slightly less than the Diameter of the 11/2 inch finish thread?Ive never done this before ,all help appreciated?chipmunk":6qit9wwx said:You really only need one tap - either a taper tap or a plug tap for through holes and in wood a sharp carbon steel tap would probably be the best.
A HSS tap will do the job too but it'll give less tear-out if it's sharp. However, sharpening a tap of that size isn't particularly hard. You ought to be able to just touch it up fairly easily and quickly with a Dremel and a small AlOx grinding wheel - Just concentrate on refreshing the leading edge of teeth in each of the flutes.
This may be obvious but I'd use either a cross-grain, rather than end-grain, piece of mock-hogany (sapele) or MDF for your fittings and the other thing to try would be slightly less thread depth than normal.
A 1 1/2" x 6TPI tap should use a tapping drill of about 1 11/32" or 34mm but an 1 3/8" or 35mm drill will be deep enough and it'll be much easier to cut.
HTH
Jon
Thanks for your help ,At the minute I don't have a Chuck for my Union Lathe,I kept my 1inch x8TPI Chuck ,which serves no purpose.What help can the ISO chuck backplate be in relation to 1x8 TPI chuck.if any? Or would the backplate be of some assistance in relation to making a Vacum Chuck ?CHJ":1b8e645r said:You might be better off getting an ISO chuck backplate as a foundation for your chuck.
http://www.toolpost.co.uk/pages/Chucks_ ... chuck.html
I only have my Gradute Lathe,so I'm in the process of buying a suitable threaded chuck ,I was hoping I'd be able to buy some type of Threaded Adjuster to screw into my 1x8TPI Chuck(Ruthland Dakota XT700 Chuck) and save me money When Chas mentioned the Versa Chuck Backplate ,I know what he means Ref, Vacum Chucking,but,as he mentioned the backplate,I was wondering could I screw theVersa Backplate (with suitable threading) onto the back of my XT700 Chuck,thus,converting it to fit my Union Lathe(11/2inch x 6TPI)?and,saving me a lot of money.Either way,once I have a suitable chuck,I would like to make Large Zplatters,thus the Vacum Chucking process.chipmunk":189c7sy9 said:Chas was suggesting it for a one-off backplate for your vacuum chuck fitting and for that he has a good point because you know it'll fit and there's no need to buy a tap.
If you still want to go this route then here is some more information on taps and wooden threaded fittings FYI...
http://www.davidreedsmith.com/Articles/WoodenFaceplate/WoodenFaceplates.htm
...but if you haven't got a chuck at all what are you expecting a vacuum chuck to do for you?
Most of us have 4-jaw scroll chucks and no vacuum chuck ;-)
HTH
Jon
phil.p":29q98ek5 said:That SK114 is threaded 1 1/2" x 8. A graduate is 1 1/2" x 6. I zoom in on these things as I have 28 - 80.
phil.p":3aigvfhv said:... I was tempted by a Versa Chuck until I was with my friend when he attempted to sort out a problem (which was a manufacturing fault) over the phone, when someone with 40yrs experience of lathes and two very qualified engineers were told they didn't know what they were talking about....
