YorkshireMartin":b93itqrh said:
...To me, your budget of only £10 for an engineers square stands out as being under funded and perhaps the wrong choice. If you're looking at making furniture, you'll probably want a combination square rather than an engineers square to start with. A good one will set you back around £100. If there is one thing I've learned on my woodworking journey so far (I'm a beginner), it's absolutely and utterly essential to have at least one *accurate* reference of that type. There are not many brands around which offer the accuracy necessary for all but rough furniture making. For me only Starrett, Moore and Wright and Veritas spring to mind. Starrett do a set for about £130 which has a protractor, a center finder and a combination square with a metal ruler. I use mine constantly, more than any other tool, justifying the cost. It is without doubt, my most essential purchase...
...The rest of your list sounds fine, but unless you know you have a preference, I'd avoid the wheel marking gauge and go for an Irwin/Marples mortice gauge, which allows either single or double pins...
Other comments: You can make a fence for your router yourself with a bit of profile aluminium and a couple of clamps. You'll need abrasives to go with your orbital sander, which often aren't cheap so need budgeting for. Drill bit wise, whilst not the best quality, I have found the Bosch X-Line sets to be reasonable. A block plane can be had for much less than £40, check out ebay for an old stanley 110.
Edit: Do you have dust extraction already? If not, I'd make that a priority.
At the moment I can't justify spending £100+ on a set of squares. The ones we use at college cost maybe £10-20, and they work fine for the skill level I'm at right now.
I actually much prefer the Veritas guages to the traditional style ones, I've been wanting to pick one up for a while.
For the drill bits, there's a £25 Makita kit at ScrewFix that my boss got given a few weeks ago on some promo, it's a great little set and the bits are surprisingly good for the money.
After picking up a brand new Stanley No. 5 for £20 the other day, I'll definitely be buying the block plane 2nd hand.
phil.p":b93itqrh said:
Keep an eye on Aldi for "F" clamps. There are offers on Irwin augers atm - about £30 a set, iirc. UK Drills do some decent sets of twist drills. You don't mention a bench? Hunt down your vice before you build your bench, ideally.
The Irwin F clamps are the ones I've priced up, they're on offer at ScrewFix if I remember right.
I'm hoping to make a bench, other than a few small cabinets that I've made at college it will be my first big project. I'm probably biting off way more than I can chew, but benches are a good £700+ online which is just out of the question.
DennisCA":b93itqrh said:
LewisM":b93itqrh said:
- 3 good sized sash clamps: ~£75
- A Veritas wheel marking gauge: £25
Both of these I think you could make to save a lot of money, that you could invest in a better fence for your saw, or a better router. I made 6 wooden bar clamps from scrap wood and some threaded rod and nuts, spent less than 20 euros on them and have had lots of use for them. Youtube is filled with various designs.
Likewise there are loads of designs for marking gauges. John Heisz has a simple design made from a dowel.
And have a good look around 2nd hand stores and boot fairs and whatnot.
Good idea, I'll have a look at that!
I'd be worried about wooden clamps bending / snapping though, I can't imagine they're for more than light clamping?
RobinBHM":b93itqrh said:
dzj":b93itqrh said:
I imagine a 10" or 12" used planer/thicknesser in good condition could be found for £5-600.
The things on your list you can buy later as you need them.
I agree, a planer thicknesser would top of my list. It opens a whole new world of being able to prepare your own timber in any section, as flat and straight as you require. One of the 260 elektra beckum or variants is a great starter machine
Yep, I would much rather get one too, but unfortunately I've had to scrap that plan for now. The workshop space isn't mine, a family member is lending it to me. It's been made clear that a planer thicknesser would be too noisy, and that the shop space might only be available for ~6-8 months. Clamps or tools can be boxed up and put away, but if I've got big, heavy machinery there when the shop gets taken off me then I'm going to have a hard time housing it.
