Good day
Today I was cutting boards to 80mm strips, and in the middle I realized that I have to cut different size and then go back and cut again 80mm.
I wanted the cut to be exactly as the first 80mm, so I made a stop to return the fence to the same position as before.
It worked so good that, I had to share it with you.
The stop is made for EB PK255 but I think that you can make it also on other table saws.
Regards
niki
Regards
niki
Code:
[img]http://i158.photobucket.com/albums/t104/nanikami/TS%20fence%20memory/FM1.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/TS%20fence%20memory/FM2.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/TS%20fence%20memory/FM3.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/TS%20fence%20memory/FM4.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/TS%20fence%20memory/FM5.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/TS%20fence%20memory/FM6.jpg[/img]
