davin
hello all.
Have to make something similar to the this,
Will be two pullouts side by side, taller one about 1850mm high, both about 800mm wide, and a pullout length of about 700/750mm.
Have found some runners which look like they will work (also the only ones I could find that will support the drawer base from underneath as well as the side.
Trouble is they are a bit pricey.
https://www.gsf-promounts.com/titan-b-97-137-kg-pair/
Just wondering if anyone has done similar and what you used.
Davin
Davin
