Racers
- Joined
- 22 Apr 2005
- Messages
- 9,172
- Reaction score
- 132
Chaps
I was commissioned to make a ring box for a wedding, so I decided to make a heart shaped one.
So the tricky bit was making it open, I needed custom hinges.
I dug out some offcuts of 3mm brass and cut some P shapes out and drilled 1.6mm holes in them.
Hinges by Racers, on Flickr
When strung on some brazing wire they looked like they would work.
So I cut a piece of Padouk to the rough size planed one face flat and marked the highest points of a heart shape I printed out.
Then saw and chiselled out slots for the hinges, I have a home made 3mm chisel which helped.
Once they fitted I cut the heart shape drilled out the cavitys for the rings, and made some inserts to hold the rings from foam and suede.
Drill a couple of holes for magnets and filled a notch for easy opening.
Heart ring box by Racers, on Flickr
I gave it a coat of Wood silk furniture polish which showed up some faults.
Heart ring box waxed by Racers, on Flickr
Heart ring box open by Racers, on Flickr
So a bit more sanding and a coat of Renaissance wax and it was finished.
Photos now sorted!
Photos now sorted!
