Would I be able to do this with a router table
i would think your router should fit the plate ,but not sure what you mean about fitting it into your bench as its free standing router table
I can see that one might want to embed this into a workbench if you had you had a really long one down the side of your shop...
I guess thought that you would have problems then getting the featherboards etc in from the side, and making various adjustments. I did do this once with a triton router table top, where I did not have the base for it, and sort of worked ok, except I had to have the table higher than the surrounding bench.
I think if you really really want to build a router table into a workbench you are better off doing it yourself.
Also, isn't that router table ALWAYS on offer? They should just own up and cut the price permanently ;-)
I think you would definitely be able to mount this into a bench, you'll be able to remove the steel legs/frame from below. But if you just want a router 'top' to go into a bench then check out the triton router top or a kreg?
Well the table arrived from rutlands today and I decided not to use the legs and make use of the spare bench room I have available, I am quite impressed with the sturdiness of the table I intend to see how I get on with it mounted in the bench before deciding if I will attach it to the legs.
