onlinename
Hey guys,
So I am renting a shed in Kent as a workshop, it's quite small, has a double glazed entrance door and the landlord put some insulation over the wood and covered it with plasterboard.
The floor is bare concrete and I will try to put some 3"x1" on it and then some insulation from Wikes called T & G Chipboard Flooring 18x600x2400mm
Is there anything else I can do without the use of a de-humidifier to reduce the humidity? and do you reckon that the floor improvement will make a difference?
Also what is the norm for workshops like this? 50% seems a little too high..
Thanks for any advice!
