mickthetree
Morning all
After getting my router fitted to the router plate I thought I'd check that it was all working.
I noticed that the router bit was wobbling ever so slightly. My router (a Macallister 1/2" that I got off a forum member a couple of years ago) has a soft start so I have only spun it very slowly.
I took out the bit and collet and cleaned everything up, but still doing the same. I ran it with no collet in and it appears that it is the central shaft that is not running true. Well I can see its not
I suspect it has always done this but in the scenarios (handheld rough work) I have used it in in the past has not been noticeable.
So is there anything I can do to correct the wobble? replace bearings? or is it time to get a new one and save this for rough work?
It didn't cost me much and I feel I have had my monies worth out of it. If I can fix it for not a lot that would be great as it has tons of grunt and fine height adjuster (and I've already drilled the plate for it!
