WoodAddict
What's your thoughts on it. I cut a box out on the bandsaw from a willow log and I've found that it's very "hairy?" I don't know how else to describe it. I find it impossible to sand smooth. I don't mind on this project as it's quite a rustic looking box so as long as it look nice when varnished, I don't mind if there is a little texture to it. The only thing bothering me is that I can't seem to get the gluing surfaces flat. The bits I glued last night seem to have held well but I've not got a lot of confidence in the joints as there are small gaps where the wood surface is uneven.
Using a finer blade on the band saw may have made a difference but the cuts were quite thick so I didn't want to risk my fine blade.
Is this a characteristic of the wood or am I missing a trick?
TIA
TIA
