Hi
Now that I am retired and wish to learn how to use a router and possibly take it up as a hobby, I would welcome advice on the type (fixed base or plunger)I should be thinking of buying. I think most of my projects would involve the use of a router secured to a router table.
I have a router table, purchased some years ago, which has seen very little use because when I first tried routing I got bored with the amount of time it took to change a bit (fiddling about under the router table) and also the fact that my bits, if pushed right in to the router and retracted slightly, were not then protruding fully above the table level so as to use the full cutting surface of the bit.
Things have moved on since I last looked at this sort of thing and collett extensions etc seem to be a suitable method of resolving at least one of my previous problems.
The router table I have is is a Wolfcraft-B6156506-Router-Table
I do not know if I am going to take to this but I would welcome any views on the type/make of router I should be looking at. I obviously don't want to pay out for top the range stuff but would not be averse to spending up to about £200.
Advice would be appreciated. Thanks in advance.
Ed
Ed
