What tool do I need for this? Smoothing after hollowing bulk
Tetsuaiga
4 May 2012
UK
I need to make a bowl but not a round one like you'd make on a lathe. A little more like a tray.
My plan is to remove most of the material first with forstner bit at drill press.
Can anyone suggest what I should use next, the result after drilling should be like a stepped formation, deepest at center. So i need to take it from stepped to smooth surface. What's the best tool for this? Can be power tool or hand.
Suppose a gouge or mini convex plane would work?
Thanks.
Not sure I've understood exactly what you want to do but this might help - tray made with Forstner bit then cleaned up with router: https://www.youtube.com/watch?v=Okwhl-yNKCU
Thanks for all the suggestions.
The main difference from it being a tray is it won't have a flat inside surface. It's more like a bowl but it's not going to be perfectly round, more oval with quite steep edges.
When browsing in WH Simiths recently, I noticed one of the woodworking magazines, (The Woodworker, I think), featured a project similar to what you are describing.
Might be worth checking out.
Ian
Arbortechs are quite fierce I would use chisels and gouges or sanding drums and bobbins on a dril/dremel
Matt
This was done with a 24mm sow-back gouge.
And this was done with a couple of gouges.
If your tray is wide a sow-back gouge is needed to do the level section in the middle..
I think i'll go with the bent gouges and maybe follow up with some kind of flap sander/scraper or something like that.
Yesterday I found a small bent gouge and gave it a go quickly on some beech, it works much faster than I expected =).
The grinder attachment look a bit too messy and I work at home so the noise wouldn't be good.
Thanks again.
Is this what you had in mind ? :D
