what size bit for housing 18mm MDF from B&Q
John McM
9 Sep 2006
Near Portsmouth, Hampshire
If it's not a daft question. 18mm is too small, 3/4" is a bit loose, what does every one else use? or do I have to make do with tapping the fence over?
Many thanks
How loose is the 3/4" slot?
3/4" is a shade over 19mm so you may find a 19mm bit is the one to go for else its a fine adjustment with an 18mm bit.
Incidentally when you measure the MDF is it 18mm? Measure the MDF and you'll have the ideal cutter size, I guess it will be 19mm.
Don't measure or test fit the factory board edge, cut at least 100mm into the board, cheap "contract" grade MDF will be a bit swollen at the edges.
Jason
I find that a 3/4" cutter works well for me.
Alternatively, check out the current issue of British Woodworking - Steve Maskery has made an excellent, fully-adjustable housing jig that'll allow you do rout out any sized housings using a smaller cutter - just use an offcut of the MDF as a spacer to set the jig. :wink:
Thickness seems to be a shade over 18mm. 3/4 bit lets panel wobble slightly in housing, might be ok when glued and pinned. Can you get different grades of MDF? I use B&Q for it as it's so cheap. Wealden do an 18.5mm cutter but are out of stock. I'll check out that housing jig anyway. I was jusr curious as to what others do.
Thanks gents.
You certainly can and - like most other materials - you get what you pay for.
Many now use moisture-resistant MDF (MRMDF) because of its much denser construction and its ability to take a sharp profile without difficulty. Particularly useful for kitchen cabinet doors, drawer faces, base cabinets, kickplates, etc., but it is more expensive.
Look at the core of the typical shed's (B&Q, Focus, etc.) MDF, then pop into a timber yard and see the difference - again, for a small premium.
jasonB is more knowlegable than I am, but I think I've covered the basics. :)
Ray.
Although I have not seen the latest British Woodworker it sounds like Steve Maskery has the same jig that I use for my housings. It is easily made and can be adjusted for any thickness of material. I always use this jig as once set up to the thickness of the material it is so quick and accurate. HTH. :wink:
As Ray says there are a lot off different grades and qualities within these grades.
The low price you pay for standard MDF in the sheds is a direct result of the amount of wood pulp that goes into making the board. There is a lot of air in the boards which results in a very "fluffy" cut edge as the fibres are not as tightly compressed. This will become very apparent when you try to paint the boards :(
For this reason I do not use standard MDF prefering to buy MR MDF usually by Caber though Medite is about the same quality. The slight cost difference is cancelled out by its easier working & finishing qualities.
Medite has a thickness tollerance of +/- 0.15mm on 18mm boards, expect this to be a lot higher on the cheap boards. Also if you buy a bit to fit the current boards there is every chance that the next batch will be different even if B&Q source from the same supplier :!: Thats why I join my carcases with biscuits :wink:
Jason
John,
Travis Perkins sell MR MDF - but the quality is not the very best! I buy mine from a specialist sheet materials supplier - there must be one locally.
As for the router cutter - I use an 18.2mm cutter from Trend for exactly this job. It's what its designed for. The fit with 18mm MDF is absolutely perfect!
http://www.trend-uk.com/en/UK/product/4 ... meter.html
Dan
Have a try of Edens, they have a depot on the south coast. Keep MR by Caber, Medite & kronospan.
Jason
