Weapon of choice
Racers
22 Apr 2005
Hi Chaps
This my weapon of choice a old Record No 5 1/2 with a welded side and a Hock blade and chip breaker.
It works very well after a lot of fettling, I made the handle and tote from some stripy Teak.
What's your go to plane?
This one is definitely one of my favorits. It's a newer Nooitgedagt which had a thin blade of questionable quality. The edge tended to curl up even on soft woods. It also had a gaping mouth, a horrible laquer finish and rather square shape. Luckily I still had a prewar Nooitgedagt blade, laminated and much thicker. I had to do a lot of fitting, removed the laquer and shaped the backside into a coffin shape. It's now near perfect. The blade has very hard steel, almost indistructable. I use it for almost anything, all kinds of smaller jobs, carpentry stuff, but it is also a pretty good smoother.
Stanley 5 1/2 with a quangsheng blade and clifton chip breaker. Or the Rider low angle block plane I bought the other week.
I got one of those, off ebay about 7 years ago, it came with a thick iron, which does take and keep a good edge. I have it working really really well now. It is a delight to use it (any excuse) Another favourite is a "new old stock" razee marples jack off of ebay again, probably 40 to 50 years old. It has a closed type rear handle, thick tapered iron, again it cuts beautiful, swish, swish, it is a pleasure to work with it. I especially like how you can totally feel the lie of the wood under it, even when the board is just a few shavings out of flat you can sense it, and can feel when it is levelled after a few more passes. The wedge adlusting is second nature now, far quicker than messing about with slack adjustment wheels....
13 1/2 inch dovetailed panel plane circa 1860 not a particularly tight mouth, not dead flat, but the first plane I pick up for general duty in the workshop, and used on a daily basis. Fitted with it's original Marples tapered' laminated iron which is superb and holds an edge for ages Lots of scratches in the sole although as a rule I try to avoid planning nails or lumps of grit!!. No backlash on the adjuster mechanism, and the lateral adjustment is very smooth.
Well it'd be one of these, ones on the left for rough stuff, ones on the right for the nice jobs. Depends what im doing really, im not a "if you could only have one plane" type of person :wink:
    121.3 KB
My "go to" planes: Coarse, medium and fine.
Coarse: a 1960s Record 05 with brazed repair to left side. Medium: a "warfinish" 04ss with broken right side. And Fine: a Clifton 3 bought in 2009. They each do what I expect of them, well.
Cheers, Vann.
    182.5 KB
    173.5 KB
