• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Withdrawn Wadkin AGS12
Farmer Giles
The biggest tool in the box
6 Sep 2011
West Yorkshire
I have too many saws so one needs to go. This is my currently daily user, well weekly as I'm only a hobbyist.
This is how it stand at the moment, the previous owner did a lot of sled work so he cut down the riving knife and didn't use a guard. But I obtained a genuine Wadkin guard and riving knife so best of both worlds. The foot pedal off switch is included. No DC brake fitted but it doesn't take long to stop, well under 10 seconds. It is 3 phase.
Here's what it comes with, genuine Wadkin guard and riving knife, riving knife for sled work, 4 blades, all sharp, the one on it I've used for about a year so may need a tickle, all teeth present and correct. Kreg after market mitre and original Wadkin fence, the fine adjuster works too.
it has dust collection built in complete with an access door for when you drop the nut down there when swapping blades ;)
Other general views
The motor does not indicate it is dual voltage so a VFD may not be viable, however it does look a standard motor frame size so if single phase is desired, the motor may be able to be swapped.
From experience of putting an AGS10 on a pallet, that only just fit after taking the top and bars off. There is no way this will go on a pallet so pick up only. Don't bid if you can't pick up, no point. If your very local I may be able to call on a friend with a trailer but he won't ship across the country, probably a 25 mile radius and will need a hand off with it. I can help putting it on a trailer at my end, I'll have to take the top off to get it out of the workshop.
I would like £1200 for it. I'm situated in the hills around Todmorden. OL14 is the post code district, stick that in google maps to see my general location.
I'm about to put a DeWalt DW1150 10" planer thicknesser on the forum too, just going to take pics.
Regards
Andy
Hi Andy.
Do you still have the DW1150? If so what were you wanting for it?
Thanks,
Simon
Hi Simon
I do, I've just bought two new rubber rollers for it but not had chance to fit them yet.
Evidently I under valued it by a fair margin last time I advertised it, once I have fettled it I intend to stick it back on the forum at a fair but more realistic price. By all means PM me if you want to take it as is before I've swapped the old ones out given your relatively local, I'm up against it time wise at the moment.
Andy
