Verneer adhesive
hammer n nails
18 Sep 2011
east sussex
I was given a large bottle of tightbond verneer adhesive could I use this for glueing up some birdboxes or would it not be strong enough seems a waste not using it as I don't do veneering
Sorry to veer away from original point but I am about to use the title bond veneer adhesive for a sizeable amount of veneer img. I've never had issues in the past. Is this a known about issue?
I've used it for small veneering jobs and had no problems with adhesion or creeping - but it does separate after a while in storing and takes some serious mixing to get it back to anywhere near it's original consistency. I know Peter has had some issues with it and it is not one of the adhesives he uses on his Veneering & Laminating course so I'd be a bit wary if you have a large job.
i use it for loads of veneer 2 ply pressings as it does not bleed through some woods as bad as cross linked PVA, i must use it quick as i have never had any separation issues, i will know to keep an eye out for that though as im ordering more & more & tend to have 3 or 4 large bottles on the shelf.
