I apologise if this is the type of question that gets asked all the time but I have have been looking around for a while and cant quite figure it out.
I just got a union jubilee in good nick apart from the fact that the previous owner was in the process of switching over to single phase. So I have a lathe in stock form with switch, footswitch and 3phase solenoid type switch in the base of it. but the motor is single phase. I think this is as far as he got.
My main question is can the solenoid switch (not sure what this is actually called) be used to switch single phase and make use of the original power button and foot switch (emergency stop)? Can I just attach my negative and positive and just leave out the third wire (yellow). On the motor side of the switch there are three black wires for the the three phase motor, can I just use the two which connect to the neg/pos and run these to the motor? I would replace these with relevant red/black wires.
I know I could buy a whole single phase system but it would be nice to use the original push buttons and top have an emergency stop which can move about on the floor.
Thanks in advance, damian
