I have a miniature set of turning tools. The ones I have are from Proops Brothers or similar, so pretty cheap, but they were ok for starting out to see how I got on.
You get similar sets from Henry Talor and others for more money - it's a set of 5 with a 3mm and 6mm spindle gouge, 6mm skew (oval I think) and a small parting tool.
My problem is with the 6mm spindle gouge and the skew. Someone I know recommended the tools and he said I could just sharpen them on a disk sander and then use a slip strop to finish them off because they're so small. That works fine but here's the but....
At some stage I've messed up the shape and now I don't know how to get them back or what they should look like.
Both tools cut better on one side than the other, not sure if it's technique or shape related but probably a bit of both.
The spindle gouge leaves a rippled surface which doesn't seem right? and doesn't feel right. Cutting towards the headstock is much worse than the tailstock direction, same with the skew.
The skew definitely isn't right. It now seems to have a curve to the edge which I'm guessing should be straight? and it's not cutting that well. I had trouble yesterday as one side felt sharp but not the other.
I have a commision to make 2 pens for xmas and I can manage away with them. Once sanded the pens are fine, but it's not ideal. I tried turning an acrylic blank yesterday for a xmas present and that really highlighted the fact they're not right.
How do I fix them?
Thanks,
Jennifer,
How do I fix them?
Thanks,
Jennifer,
