I hope someone can help me with this!
When I switch the saw on I am met with a loud buzz which only stops when I switch off. Axminster have diagnosed this as a capacitor failure. I have bought a new one BUT I can't remove the cover off the unit on the motor. I have removed the left hand panel and lowered the blade. The two screws holding the capacitor cover to the motor will not shift. I cannot get enough leverage on the screwdriver because I am working from the side rather than at the end of the screwdriver. The distance from the screw head and the rear of the machine casing is only about 160mm.
Has anyone else had this problem and how did they solve it? Axminster service department cannot give me any advice apart from getting someone else (probably younger and stronger) to try it for me. It is out of guarantee and I bought it in February 2009. If I ground off the screw heads with a Dremel I would not be able to replace the screws - how important is the cover?
Brian
Brian
