dovetail2007
Hi Guys,
Being in the position of many woodworkers; short of cash and a large list of machinery needed (I predict I'm half way down the infamous slope ) I have decided that I need to produce something cheap on materials, knock out a load and sell them, to fund the purchase of machinery and/or higher quality materials.
So, trivets it is - they should be cheap/easy/quick to make and are always needed by people.
I have decided to go with the cheap softwood from Wickes (18x34mm) which I have used extensively before. I plan to cut out the knotty sections of the timber and with the pieces remaining, rout a rebate on two faces, and a profile of some sort on another - leaving only one edge standard.
The profiled edge will be on the outside top, and the two rebates on the inside.
One rebate will house the tile (10x10 wall tiles) and the other will hold the base (3mm MDF or ply)
Mitre the corners, glue and clamp and then insert the base into the rebate - glue and then inlay the tile.
Depending on the tiles I get, I may stain the pine prior to assembly.
As usual, a couple of questions:
1) Anyone know if shops like "Topps Tiles" sell individual / small quantities of tiles? I don't really want a case all the same..
2) Would the pine need to be preserved, due to the heat which it will be exposed to? I reckon that most pots/pans/dishes/mugs have cooled down within 15minutes, so the timber will only have to withstand the heat for around 15 minutes at a time - will this warp/bend/shrink the material in this time?
3) Similar question to 2) but relating to the tile adhesive
Cheers, and as always I await your excellent responses
Sam
Sam
