Tri-Ply Huge boards
peter flavell
25 Jun 2012
rutland -leicestershire border
I have recently moved back to England from France where I used a timber board product called Tri ply. It is as the name suggests a 3 layered pine board available in various thicknesses from 19mm to 40mm and dimensions 5 metres by 2 metres . It is also comparatively light in weight .
I have been unable to find a supplier here ,is it unavailable here?
It is generally available in France, even cut to your dimensions at the larger D.I.Y. stores
Does anyone know if it is available in the UK?
The nearest I've seen here is some fairly coarse plies about 4mm thick often with voids, with a finer skin on each face of brown splintery timber. Awful stuff only a small step up from shuttering ply.
Not sure what name it goes under.
hth
Bob
