woodbloke
I keep on re-visiting my strop on the honing bench...just a lump of leather glued to a piece of mdf and smear of Vaseline with Jewelers Rouge as a cutting medium. What I tend to do is to finish on the SS 3M films (1 micron) using the 'Ruler Trick' on the reverse (or back) and then a couple of passes, no more, on the honed bevel with the strop, followed by another quick session on the back using the RT.
I know that there's an argument for saying that there's a minute amount of 'drubbing' of the honed bevel that takes place if stropping is done and I know that PaulC will show us his mdf and Autosol way...but I've found that that method doesn't work for me as the edge doesn't get perceptibly sharper, whereas on the strop, it seems to.
Each time I sharpen, I go back to the 3M films and re-hone, so the strop is not used as a method of honing, merely to get that final smooth, polished edge after the 1micron film. Also bearing in mind that Jeweler's Rouge is just about the finest abrasive commercially available (is there anything that cuts finer?) I dont' think the so called 'drubbing' issue is relevant as any rounding over that is created will be removed at the next honing.
How good is Chromium Oxide (as sold at WH) compared to JR?
Interested to hear others thoughts on the matter - Rob
