Bkn
Long time lurker first time poster here
I'm trying to figure out the best way to put together a stool similar to these:
edit - meh caught by filter.. address is: imgur dot com / DUwW1 dot jpg
and also what materials to use.
I'd like to keep material costs as low as possible i.e. use thinner ply/mdf but obviously want it to be very stable.
I'm also confused as to what joints would be best to use - partly because this will most likely depend on the thickness of the sheet material I use.
So:
Ply or MDF (considering weight needs to be kept low enough for it to be moved easily)?
If I use, say, 12mm ply is that enough thickness to screw directly into the edge of the panels at the corners?
Would it be best to have a panel for all 6 sides or use a couple of braces on the bottom for the feet to screw into?
Any tips would be greatly appreciated, thanks
So:
