+1 for tulip wood (mine were painted)..
I've recently done several internal doors out of it. I used 50mm tenons on the rails, 30mm on the muntins and plywood for the panels. I tried two ways to do the moulding. 1) Routed the moulding on the rails, stiles etc. and used a mason's mitre at the joints; 2) applied the moulding after the door was made. The mason's mitre's were tricky to avoid getting a gap; but, I think they were slightly less of a pain in the ass than number 2. I wished I had coughed up and bought rail and stile router bit set; but, I'm not sure if they work with mortice and tenon joints. I agree with Chris (kattelwood) that you need decent joints.
You should also include a middle hinge if possible.
Regards,
DT
