Steve Maskery
Hi all,
I mentioned a couple of weeks ago that I had ordered the Tilgear aluminium router plate. Well today I have actually got round to fitting it.
It's all pretty much good news.
1. It's the same overall size as the Rousseau plate it is replacing. I just needed to ease the edge of the recess a little, but that was because the R plate was also too tight and I'd never got round to doing anything about it.
2. There are good-sized dimples on the underside for drilling mounting holes for many common routers, so no guesswork there.
3. Good levelling by grub screws at all four corners.
4. Starter pin in a choice of two positions screws in place.
5. You get 3 interchangeable insert plates which screw into place. One is blank for any size you want. I've drilled it at 13mm so it will take any cutter up to half-inch.
6. Best of all - it is flat. None of this crowned nonsense.
So are there any downsides? Well yes, but not ones I can blame the manufacturers for, really.
1. The biggest aperture without any of the centre rings is smaller than the Rousseau. Not by much, but enough to prevent me from using my panel-raising cutter . It means that I'll have to put the old plate back to do that. But it's not something I do very often, so I can live with that.
2. I'm not sure yet how I feel about having to remove three screws just to get the centre ring out. The Rousseau one just popped out as I raised the router, but could be a pain to get back in. This is easy but a bit more trouble (find the right screwdriver etc, etc.).
3. I'm not sure if it is possible to get just the centre rings. It wouldn't actually be difficult to make some on the lathe (I think even I could turn one) but it would be nice to be able to buy a pack of, say, six blank ones, for any diameter bit I want to use.
Bottom line - am I glad I bought it? Yes.
No affiliation.
Steve
No affiliation.
Steve
