mailee
My Elu 1251 radial arm saw seems to have a wobble on the blade. It has been like this for some time after hitting a knot and stopping! I decided to put a new blade on it and did this today. it still has some runout on the blade of about 1/32". I checked the blade with another one just in case I had bought a duff one but this too was out about the same amount. I checked the arbour as best as I could and it seems to be straight although I don't have a dial guage to check this with. (I used a piece of metal clamped to the motor housing and almost touching the arbour) When i replaced the inner flange and spun the arbour by hand it had the runout again. My question is could it be the flange that is bent or will it be the arbour? It is not a lot of runout but enough to make the blade wobble and give a wider kerf. A new flange is about £18 so I could replace this to try it but unfortunately a new arbour which is also the armature is around £82! I think I will put up with the wobble if this is the case.
