This is the tenon jig i made a couple of months ago. a lot of the jigs out there couldn't manage to cut a tenon big enough for what i wanted. i borrowed some ideas from Matthias Wandel at woodgears.ca however his jig also would've been too small.
You can see in this picture the adjustable stops which let you set the jig to cut both sides of the tenon which is handy for making doors as it enables you to set it up once and this will cut all of your tenons.
This is the first time i used the jig to make some "rustic" stools for a customer.
I've since made a door using the jig. so i cut the tenons on an 8" bottom rail which went through a 4 1/4" stile. could possibly cut slightly more than this but it's adequate for most doors which is mainly what i wanted it for.
