tarnishing on oak...help please?
Davidf
21 Apr 2007
Hi,
I don't know if htis is hte right place to put this....
I'm trying to finish these cones as part of a proejct but I am not happy with tarnishing on the surface......
http://s134.photobucket.com/albums/q115 ... copy-1.jpg
...hope the pics how it ok.
The wood is oak (I hope!), it have noticed that pieces cut off fairly recently don't seeem to show this so much....is it a reaction with the wood to air over a couple of days?
It doesn't sand off easily!
How do I get rid of it.....can anyone help , please?
cheers,
David
ps The first pic (though the focus isn't brilliant) shows it best, near to the 50p piece.
If you are referring to the dark patches forming on the surface I suspect they are due to moisture either in the wood or local surroundings (even handling) reacting with iron or other contamination, there may even be something in the wood that's oxidizing when exposed to moist air.
If it is a stain caused by contact with iron (like a clamp or steel wool), it can be removed with dilute oxalic acid.
