Taps and dies
Bm101
Lean into the Curve
19 Aug 2015
Herts.
If you were looking a buying your first ones would you go for joblots offf ebay, a set or pay a little more for selected sizes and build up your collection as you went. With the last option, any particular make or seller I should be looking at? I've always been wary of buying sets of anything tbh.
Chris.
what material are you wanting to tap. quality singles are better, but may be unnecessary on softer materials- they quickly get expensive if you need a few sizes.
Only on Brass mate. This is all brand new to me. What I was thinking was just buying individual taps a needed. On brass I wondered if any old gear would chew through it.
My ebay set of 4 of them go through hard woods and mild steel without any issue. Used them a few times now, always figured I'd buy posh ones if I found myself wanting to replace them, but these haven't let me down yet.
sets usually contain around 40% that you will never ever want. I have sets of stuff that contain 40 year old unused items.
Buy what you need, when you need it. And if you are only EVER going to work on brass, cheap will be ok (as long as it isnt the deaded silverline). but normally you find yourself being asked to do odd jobs for other people once it gets out you have the bits, so buying a good quality will be a better option.
If you are cutting threads through steel or anything harder (rather than cleaning up a thread) I would always go HSS instead of carbon steel (nothing wrong with carbon steel but sets tend to be quite soft). I personally buy as I need them because good ones can be expensive. Arceuro as linked above sell reasonable stuff. Also try Cromwell Tools and Tracy Tools who sell individual taps and dies. Dormer and Presto are good makes to look out for although there are others.
I've got an assortment of old taps and dies and also a cheap Chinese set from eBay.
I'd far rather use the old ones and should not have bothered with the set.
There are lots of good old taps and dies around so you don't need to spend a lot for decent quality.
In my experience anything marked as HSS will be good, and it's the sort of marking that can be copied out by a seller who doesn't know what they have got.
If you do buy new, be aware that terminology is different in UK and USA, so Chinese makers can get confused.
Here, a set of taps consists of taper, second and plug. In the USA they call them taper, plug and bottom.
Oh and also, cheap dies are fixed diameter, not adjustable. Ok for cleaning up an existing thread but not so good for making a new one.
As far as drills, taps, dies, sockets, ring spanners are concerned - everything I ever bought in a set in the last 35 years is complete. I've no idea where the single items are. That would lead me to buying sets - you'll always have some you'll never use, but they're invariably quite a bit cheaper than buying singly. You can always replace one with better quality if needs be. Besides - how do you know which you'll need at any given time? That depends what you do with them of course.
IMO, your decision depends to a large extent on what threads you want.
It's certainly true that sets contain sizes you'll (almost?) never need. OTH, if it's metric you need then, you'll find the cheapo sets appearing in Aldi & Lidl are plenty good enough for general work, especially IF you use them carefully and keep them clean/swarf free. Those comments apply particularly to working on brass, especially if it's "half hard" brass you're working on (which it most probably will be).
Those sets usually only include 1 tap (the 1st or 2nd taper) but unless you want to go deep into brass, or need blind holes (in which case you'll need a plug or bottom tap), they'll do you fine. They have the advantage that they include the correct size drills (tapping and clearance) for each tap in the set and also the correct die. The dies are not all that easy to adjust (my set has solid dies rather than split dies) but there IS a little bit of thread cutting adjustment possible.
As you go on you may well break a tap or two, though you should soon learn the feeling of when a tap's about to break - basically if the tap wrench turns a bit without taking the tap with it, STOP! Then CAREFULLY free it.
But if you're lucky you can grind the broken one/s down into plug/bottom tap/s and replace it/them with better quality one off tap/s. If you've broken one or two you'll at least know there's a good chance you'll need that size/s again.
The decision I faced when first "emigrating" to a metric country 20+ years ago but being already well equipped with loads of good quality BA, Whit, ME, SAE, BG, etc, etc, taps and dies led me to do exactly as described above and I haven't regretted that decision once - very cost-effective.
And BTW, although a cheapo set (no doubt from China), on mine at least 75% of the original taps in the set which I do use regularly are still the original cheapos.
One other advantage of a cheapo set is that everything's all neatly boxed - on NO ACCOUNT allow taps to bang around loose in a box or drawer together.
If you do need Imperials or other "special" threads though, I'd agree with the general advice above - buy just the sizes/threads you need in good quality singles, not a set. Once you have gained a little experience of your own particular work you'll know for which sizes and threads you'll normally need 1st or 2nd taper taps and/or plug/bottom taps. And it you can, get split dies, they are MUCH better and easier to use than the solid dies in sets like the above.
HTH
AES
Most of my taps and dies have been bought as I needed them and are by well known manufacturers. Most of the T&D sets I've seen have been low budget. Same thing with drill bits. I could have spent a fortune on buying a set with .1 mm increments but if I need a 6.1mm or a 7.2mm drill bit I buy one. There isn't a right or wrong though provided you're happy with the quality you're buying.
Forgot to add. If you decide to tap other materials, particularly steel, get yourself some tapping compound.
Sorry, posts crossing (busy thread this)!
Also agree with woodpig about cutting lubriacant, but for brass, even though the books say "not necessary" I've found a drop of paraffin or WD 40 invaluable for working brass (both in the lathe and by hand).
AES
I must remember that. I tapped some brass the other day and found it a bit "sticky" so to speak.
Yeah, it's still a bit "squeaky" woodpig, but it clears the swarf better and makes an overall nicer/cleaner thread. Ordinary 3 in 1 will do at a pinch, but paraffin or WD 40 works a bit better I've found.
This is especially true on the lathe (but watch out, if you're not careful it will still spray you with fine chippings which gets into the neck of yer T shirt, which then you end up emptying into the bed as you get undressed - definitely NOT impressive for SWMBO - DAMHIKT) :oops:
AES
I have a very eclectic collection of odd tap sizes, and I've never yet bought a set (keep intending to though). They're eclectic because I used to build a lot of electronics, so found myself needing 2 UNC along with M3, M4, etc. - some specialist plugs+sockets (Elco/Edac) won't accept incorrect substitute sizes of bolt/set-screw.
The other "uncommon" one I've often needed is M3.5, which is now standard in electrical socket boxes*. You can buy M3.5 taps with handles fitted, for cleaning the "threads" tapped in said boxes, but that's no use if you're mounting the faceplates to something else, such as 3mm aluminium plate!
For those applications, the taps live in the boxes with the specialist nuts and bolts, rather than in the tobacco tins holding the more common taps +dies. I find that easier, as some are very similar to other sizes and it's easy to grab the wrong one otherwise by mistake.
I now always use cutting compound when tapping, even brass, and especially aluminium and mild steel. The difference in result and ease of use is marked. My preference is Trefolex (other compounds are available!).
I find I get a nicer result by using at least two taps - taper + second or taper + plug - I think it polishes the threads a bit. But then I tap by hand, or in the pillar chuck with the belts removed and a weight tied onto the handle - it may be unnecessary if doing it entirely by machine.
I'd welcome advice on how to get dies started: I don't have a lathe, so it's always by hand, and on those rare occasions I'm starting from scratch, I often need several attempts to get one good thread, which is rather wasteful. There must be a knack to it!
E.
*Beware! Pre-metrication, electrical socket boxes were often 4BA, which is very close to M3.5 but NOT interchangeable. You still come across them in old houses. Sometimes you can just run a metric tap through, but it depends on how much metal is there and how worn the threads are to start wtin. It doesn't always work!
I keep a pot of cutting oil with a small paint brush in it next to my pillar drill and big vice, and use it sawing and drilling everything metallic - the theory being that if it does no good it will do little harm. :D
EtV wrote, QUOTE: *Beware! Pre-metrication, electrical socket boxes were often 4BA, which is very close to M3.5 ..... UNQUOTE:
Thanks for that Eric, I thought all electrical stuff was 4 & 6 BA (isn't that why BA was 1st invented?) but have had to do little or no electrical socket, etc, stuff since I've been here, so wasn't aware of the difference. Thanks for the tip, 'cos looking at some of my Swiss electrical bits & pieces it does look just like 4BA, and I'm sure I would have pressed on with BA.
But as it happened I got lucky. A good local tool shop where I go from time to time was having a clear out of old stock and was about to throw some rather good-looking hand and machine taps & dies away. When I protested I was allowed to take the box home and sort through what I wanted (which was quite a lot actually!) and take the rest back, paying "what you think is fair" for the stuff I'd kept. I put 50 Swiss Francs into their coffee fund (about 35 quid at the time) which made them more than happy, and I ended up with a "collection" of all sorts of stuff, including a lot of Metric Fine taps & dies, & including several 3.5 taps & dies. No idea why they were throwing the stuff out, but I was sure pleased, and all the stuff I got was good quality local Swiss & German manufacturers.
But I STILL start off with my cheapo Aldi Metric set!
Re your earlier comment about your stuff "in their boxes". OK if they're individual cardboard or plastic boxes, but if loose, and simply protected with that "dipped into brown waxy stuff", which doesn't last very long before it all splits, a good tip is to go to your local car/aero model shop where they sell neoprene and silicon tubing in various IDs. It's for model engine fuel line, sold by the metre, but cut to short lengths makes excellent tap protectors.
Re starting a male thread (using a die), yes, it's a bugger that, I sympathise. I only use a lathe for that now (run by hand or VERY slow motor) but always had trouble before I got the lathe. About the only thing I can suggest without a lathe is to make a very exaggerated taper at the start of the rod to be threaded (file it in the pillar drill so it's pretty symmetrical) and then after the thread is cut, saw the offending taper off (assuming you have the necessary extra length to start off with).
HTH
AES
P.S. @phil p: Good tip that, a bit of lubricant when doing any sort of metal cutting never does any harm and is usually a positive help. I do much the same (except it's a little tin of 3 in 1 or similar).
That is a REALLY good idea! I have a horrible thread adapter for photography to make up sometime soon, and I could probably do it that way.
