Benchwayze":zpj1r3co said:
Not knowing much more about archery, than how to draw a bow and loose an arrow, why are arrows tapered? Why not just have them the same thickness throughout?
Is it to do with the need for more weight at the lethal end, to assist in flight? I suppose there was no need for absolute accuracy on the battlefield. Wasn't the idea to let fly with a 'barrage' in a high trajectory, meaning accuracy of range was more important than 'targeting individuals'.
There are two sorts of archery: modern target archery and good old fashioned kill the other guys before they stab you with pointy things archery.
For warfare archery what you cared about was being able to loose and hit a certain range rather than a particular individual (if you did not hit Alphonse you hit Francois by his side). So most practice was done to learn how to drop an arrow at a certain range (clout shooting).
You are right that high trajectory barrages were the order of the day. Like any other projectile an arrow will follow a parabolic arc, so in order to get the furthest distance you need to loose at 45 degrees. As the enemy get closer you drop the angle which will mean that the arrows fly at a flatter arc, until eventually you are loosing pretty much straight at the target (which in warfare means you have probably lost if they have got that close to your archers).
The heavier the arrow the shorter the distance you can shoot it. the larger the fletchings the more drag, the larger the arrowhead the more point heavy it is and the shorter the distance.
However, putting more of the weight at the front of the arrow will increase the impact when it hits that target and thus give it more penetrating power. If you put more weight at the back by making the shaft thicker at the back then the point will hit and the back end will try to keep moving forwards as it has more kinetic energy and more than likely cause the shaft to flex and the point to deflect off.
The strange thing about archery is that the arrow does not leave the bow in the direction of travel. If you hold an arrow ready to be loosed you will have the bowstring pulled out directly behind the bowstave and the nock of the arrow on the string. However the head of the arrow is held on the side of the bowstave, so if you draw a line from the nock of the arrow to the back of the bow and then from the knock of the arrow to the point of the arrow they will be different by about 5 degrees. However when you loose the arrow it flies in a line from the string to the bow, not in the direction that the arrow was pointing.
This is referred to as the archers paradox. what is happening is that as the string is loosed it imparts a huge amount of energy into the arrow. The arrow being made of wood flexes slightly as it is loosed which causes it to bend around the bow (in fact it wobbles most of the way to the target). The thickness of the wood determines the amount of flex. The amount of flex should be tailored to the draw weight of the bow. So for a big 120lb warbow the shafts were about 1/2" thick. A half inch thick ash arrow is pretty heavy, especially when you stick a lump of iron on one end. It was discovered that the flex of the bow was determined by the middle of the arrow, so you caould have a shaft that was 1/2" in the middle and only 3/8" at the ends which made it a bit lighter, but it still flexed like a 1/2" shaft.
So you can make arrows straight, barreled (so that they are thicker in the middle to reduce weight whilst keeping a low flex), or breasted (thicker at the head to add more punch to the impact). There were also some that were Chested (thicker at the fletchings), although I don't know why.
At Crecy there were 6,000 English archers, each loosing 12 shafts per minute. At 200 yards you can probably get at least 2 in the air at any one time (may be 3 if you are lucky or good). At any point there were between 12,000 and 18,000 arrows in the air. With 6000 archers it takes 7 minutes to loose half a million arrows. So take a moment to think about the poor sods who had to slog up a muddy battlefield into an arrow storm.
